Adjustable Rear Suspension-a Must On Elio
lnwlf40
moline il
Does this offer any clues?
Kuda
NC
That looks like recognition of Elio's acceptance of outside expertise, and that's a powerful sign of success. When you can get your creative ego out of a project in favor of experienced and expert input, you are on your way!
Except for the Elgin Dash, totally agree! Sorry couldn't help myself....:D
Kuda
NC
I doubt they are listening ..... most don't seem to have a clue that EM exist
I think that's right, but these guys &/or their reps are at the supplier meetings:
  1. Pep Boys
    Company
  2. The Pep Boys: Manny, Moe & Jack, is a full-service and tire automotive aftermarket chain. The first store, originally named Pep Auto Supplies, was founded in Philadelphia, Pennsylvania in 1921 by Emanuel ...Wikipedia
  3. Headquarters: Philadelphia, PA
  4. Customer service: 1 (800) 737-2697
  5. CEO: R. Odell Michael
  6. Stock price: PBY (NYSE)$9.82-0.03 (-0.30%)
    Dec 31, 4:02 PM EST - Disclaimer
  7. Founded: 1921
Ocean9000
The Merry Old Land of Oz
just guessing here, so be nice... minimum load, 100 lbs., one very small person, empty fuel tank - maximum load, 700 lbs., two full size Americans, full fuel tank and a 46 lb. lasagna in the storage area. Divide the 600 lb differential by 2 (instead of 3, for a buffer) and you get a 300 lb. unloaded to fully loaded weight that the rear suspension would need to handle. Look at the rear shock above. it's beefy and at least 16" long - a good progressive spring on it would deal with that without issues, I think. Might want something else for track days, but that's a whole other discussion.
Cargo coils vs Variable rate. Well, I won't clear this up exactly, but I can say something about the tech details.
Variable rate, back in the 80's entailed a different spacing along the whole coil. As spring coils that were close spaced touched against others, the rate of loading change was different, effectively stiffening the spring.
Now on the pinching as described, this would mean that coils would not lay against each other so fast, effectively lengthening the distance a spring can compress. If it still has a variation of spacing, then it still is a variable rate. It just has a longer 'throw' before the rate climbs, since it also has a long overall travel distance. This is used to get a longer compression distance into a smaller spring package. But I should also say a tighter coil in the pinch will also be a bit stiffer section. this is like stacking different stiffness springs together, which is also a variable rate method.
So in review, there are 4 ways to get a variable rate.
1 Stack up different rated springs. (parallel or serial layouts)
2 Variable spacing, (cheapest to make, and implement)
3 Variable Coil radius. (also increases the compression distance)
4 Variable wire diameter (or wire shape) or variable material composition. (totally impractical to fabricate, which doesn't stop the aerospace industry :-) )
