Muzhik
Iowa
I don't quite understand having lots of keys on the key chain either. But I do have my work office key on my key chain and unfortunately I have a key to each building for work. That is 3 additional keys. The only coin looks cool but how does it handle chip cards? A better option (that requires merchant help) is mobile payments. Unfortunately there are only a few places that I spend money that accept it.
I started carrying my car keys and auto keys on separate rings after I made they guy at the auto place wait 5 minutes while I struggled to get the car key off the ring so he could work on my car. I have ONLY my car keys on that one key ring.
That's what I had to end up doing too; the new Dodges have very large keys; at the time, I had the Magnum and the Nitro, so I had two of those monsters on the same ring, along with 10 other keys for things around the house, and a separate 2 rings for all of the different office keys I had.
So I broke them into "groups" and ended up with 6 key rings. I would only carry the group(s) I would need for that day.
Sure beat trying to fit them in my pocket all at once.
Oh Boy, info on the dash:
Loads of Technology in Half the Width
Elio Motors Momentum v57
ago.eliomotors.com_hs_fs_hubfs_ELIO_06380_Momentum_P5_V21.jpg_010b8f9c6cf6410241757dda29e482fa.jpg
Behind the Curtain: How we made the Elio Instrument Panel
ago.eliomotors.com_hs_fs_hubfs_IMG_1377_e14532280841322.jpg_6a9545045d4bf0a0bdf7c9ca99c431d6.jpg
It’s not every day that you get the opportunity to go behind the curtain to see how a vehicle is assembled, especially one that’s not yet on the market. If you’re the kind of person who is curious and enjoys technology, however, today is your lucky day.
We’re taking you into Elio Motors’ Pilot Operations Center to see the process of assembling our E-Series vehicles. This installment is about how our instrument panel (I/P) is built up and installed. While this isn’t quite as sexy as sitting in the driver’s seat and watching the gauges respond as you accelerate on a winding country road, the amount of technology in the Elio’s I/P, as we call it, is astounding.
One of the vehicle’s features that Paul Elio often talks about is its tandem configuration, which makes it more aerodynamic. Of course, you’ve noticed that it makes the interior approximately half as wide as a traditional vehicle. This means that the instrument panel for the Elio is more compact, which also means that we have to be more efficient with our space to include all of the technology you’ve grown to appreciate in a vehicle. This includes things such as heating, ventilation, and air conditioning components that traditionally are located toward the front passenger area of the vehicle. Our “packaging wizards” on the HVAC product development team have done an excellent job of fitting existing componentry into these specific areas.
The Elio instrument panel in an inverted position.
When the I/P is in an inverted position, you can get a better perspective on the internal components. In the image above, the cross-car beam can be seen snaking through the panel. On the left side near the orange I/P fixture, you can see the I/P wiring harness bundle, which shows just how much functionality of the vehicle is incorporated into the panel.
A myriad of smaller wiring harnesses provide power and communications.
When you really want to see the complexity of what’s going on behind the curtain, the back of the I/P is the place to look. In the image above, our technician is torqueing a steering column bolt to the cross-car beam near the HVAC system’s blower motor, which lies behind the green connector in the middle of the frame. The gray panel on the top actually is the knee bolster, since the I/P module is upside down for ease of assembly. In this position, you can see the myriad of smaller wiring harnesses that provide power and communications to and from the systems that are incorporated into the I/P. These include not only the HVAC system and steering column (the column adjusting lever is visible on top), but also entertainment/radio/navigation, the instrument cluster, and various knobs that control the vehicle’s lights and HVAC.
An interesting note about the layout of the instrument panel: the controls for the Elio are traditional knobs and dials located in traditional placements, so that the vehicle feels familiar when you get behind the wheel for the first time. The stereo/entertainment/navigation components remain on the right side of the steering wheel, while the HVAC knobs are located on the left side of the steering column.
Once the I/P assembly has been built up, it’s ready to install in the vehicle. On a traditional assembly line, instrument panels, which can weigh over 100 pounds, are mated with the vehicle using an ergonomic conveyor system. In this pilot build, our technicians hand fit and finesse the assembly to ensure it’s aligned as designed.
In this pilot build, the Elio Motors technicians hand fit and finesse the assembly.
The design of the Elio’s I/P isn’t meant to prepare it just for the installation phase, however. The Elio’s panel is designed for flexibility and upgradability, which means it will allow you to eventually change your entertainment system or upgrade to navigation at any point in your ownership experience.
As you can see, we’ve been busy since the product development teams completed the engineering phase for the E-Series vehicles. As a Momentum reader, you’ll have a front-row seat as we assemble the first E-Series vehicle.
Can you make this a separate thread and not allow it to drift? (later include the others pics of the build)
Looking GOOD.
Actually, if you go back to the early parts of this thread, it's quite fitting.
There are 3 other areas that Momentum email can go, and I'm sure someone will have it those areas also.
MrWhsprs
Round Lake Beach, IL
I've never understood why someone would carry around so many keys and why they would attach them all to the vehicle ignition key. [...] People tend to keep every single key they own on one keychain. That's a lot of weight on the ignition.
My keychain has a Mobil SpeedPass, a tiny flashlight, 2 vehicle keyfobs, 2 vehicle ignition keys, 7 other various keys, and a number of key rings to divide the items into different groups. Out of curiosity I weighed my keychain and it's 6.0 oz. :-)
However, each of the ignition keys is on a quick release so when driving I disconnect the necessary ignition key and the rest of the keychain stays in my pocket or in a storage area in the vehicle. :-)
Lil4X
Houston, Republic of Texas
If you have more than car keys and a house key on your key ring, you're a nightwatchman somewhere.
At least that's what I tell my wife, who still has the keys to a Volvo she sold twenty years ago on her key ring . . . along with the keys to several old homes and apartments. Is this some kind of a sign? My daughter carries the stub of a key for her truck she twisted off a couple of years back . . . as well as a new one on her key carabiner. She also sports a collection of band logos and charms that add up to about a half-pound of iron, aluminum, and brass.
In college I carried a silver dollar framed in sterling given me by my favorite uncle at my HS graduation. The weight of that jewelry alone, swinging from my ignition key, destroyed one ignition switch and damaged another . . . not to mention wearing a hole in several pockets.
Why do we do these things to ourselves . . . we know better. :ballchain:
