electroken
As far as oil capacity, I see no reason to have a 6 qt. capacity on a 1 liter engine.
Agreed. It makes no sense at all unless the oiling system makes up a significant portion of the cooling system (think old Porsches).
An inline-3 will have a very short oil pan, so the only ways to accommodate 6 quarts are to make it deeper (tall engine, messed up aerodynamics) or use a dry sump oiling system. The Elio engine does not look like it's set up for a dry sump.
Or you could mount the engine on a angle like an old Chrysler slant-6. They were very long stroke engines and were flopped over at 30 degrees or so to fit under the hood. Not needed here with only 900cc displacement.
