I doubt the oil cooler: cost!6 quarts? I never knew that. I wonder if they have an oil cooler; that would remove some of it from the pan.
You can register using your Google, Facebook, or Twitter account, just click here.I doubt the oil cooler: cost!6 quarts? I never knew that. I wonder if they have an oil cooler; that would remove some of it from the pan.
Not to mention Tuk-Tuks, rickshaws, mini-vans galore clogging the streets of Asia and India. The efficiency of the Elio engine would make it attractive for all those vendors, delivery services, repair services, and hucksters thronging the Third World.Some members have speculated about what a foreign market for the motor would be. There are thousands of small river boats in Thailand that run a yoke mounted motor on the stern with the prop running straight off the crank shaft. They run any kind of motor that they can fit into the yoke.
View attachment 11351View attachment 11352View attachment 11353
Just imagine the vibration levels in those long shafts! Oy!Some members have speculated about what a foreign market for the motor would be. There are thousands of small river boats in Thailand that run a yoke mounted motor on the stern with the prop running straight off the crank shaft. They run any kind of motor that they can fit into the yoke.
Cooling is definitely better now days with electric fans that supply cooling when you are stuck in traffic. Another thing I learned from Jerome at the Salt Lake P5 stop was that the engine carries 6 quarts of oil which also provides additional cooling and better lubrication. I think the engineers and Paul are putting together a winner. Looking forward to getting mine. Go Elio!!
I know what mine is going to be....Does anyone know the oil viscosity?
