Easy In/easy Out?
LockMD
somewhere
Guess, I'll go against the grain on this one......I'm 5'10", a little bit of a beer belly, and a bad back. When I sat in it at the Corte Madera showing, I remember that being my ONLY negative thing. I thought it was a little hard getting in/out of. I'm hoping with the raising of the ground clearance will help a great deal though.
Guess, I'll go against the grain on this one......I'm 5'10", a little bit of a beer belly, and a bad back. When I sat in it at the Corte Madera showing, I remember that being my ONLY negative thing. I thought it was a little hard getting in/out of. I hoping with the raising of the ground clearance will help a great deal though.
I may have to wait for the crossover 3X3 AWD Elio 2.0 with a much higher ground clearance........ez in ez out.
BlioKart
SoCal
I think the P4 sits lower than the production spec. But I doubt it would be drastically taller. How much could an inch or 2 help?
BlioKart
SoCal
Problem solved
Truett Collins
Questa, NM
One thing I remember is that for some reason every time someone got out they would lower the seat as low as it would go before the next person got in. With my back once I had set down I was wondering about getting back up, but once I had adjusted the seat to my comfort I found that getting out was no problem with the seat as high as it would go. Add to that the raise in clearance planned for the production model I see no problem.
