You can register using your Google, Facebook, or Twitter account, just click here.The circumference of a 15" tire is somewhere around 6.5 feet so maybe as much as 4 feet or so. depending on where the valve stem is to begin with 4 feet could hide it an the other side. I suppose one could just put it in neutral and push it aroundMajor
|ˈmājər|adjective1 [ attrib. ] important, serious, or significant: Adding Fix-A-Flat to a tire is a major problem.
Maybe roll the tire a few inches to a couple of feet?
Yup.The circumference of a 15" tire is somewhere around 6.5 feet so maybe as much as 4 feet or so. depending on where the valve stem is to begin with 4 feet could hide it an the other side. I suppose one could just put it in neutral and push it around![]()
I'm going to see if I can get an Elio team member to define exactly what they mean by "OPTIONS" with regard to the fenders. I'll be in Okie City this afternoon. If 3Card makes it with his 20 questions, and the questions I have.....They may never want to set foot in OK again!A major ordeal? Talking about defining things down!
With consideration that the situation may be that the tire is completely flat making it difficult to roll and the possibility that the bead seal could be broken. In some cases maybe a jack could be used to lift the wheel so that it could spin to where the fix-a-flat could be used. Will the Elio come with a jack ?Yup.
6.28318530717959 feet
If the engine is still running maybe it could be powered to achieve the needed placement without any physical effort.With consideration that the situation may be that the tire is completely flat making it difficult to roll and the possibility that the bead seal could be broken. In some cases maybe a jack could be used to lift the wheel so that it could spin to where the fix-a-flat could be used. Will the Elio come with a jack ?
Your guess is as good as the next guy....snip...Will the Elio come with a jack ?
We all look forward to seeing lots of pics and maybe a youtube video.I'm going to see if I can get an Elio team member to define exactly what they mean by "OPTIONS" with regard to the fenders. I'll be in Okie City this afternoon. If 3Card makes it with his 20 questions, and the questions I have.....They may never want to set foot in OK again!
I am better at word problems than any of YOU!Yup.
