Wheel Fenders, Fairings, Skirts, Covers
Craig
SE OHIO
I'm not sure I follow. Jobeleca didn't see the need for the removable panel, I was just giving my reason for why it needs to be the way it is.
The way I read it is, you are saying you need tools to check the air pressure.
Is that wrong? If so, sorry.
H2odog
I believe what he is saying is that since the front tires are 3/4 covered (and the back worse) trying to get the valve stem in a position to check could be troublesome and it might just be easier to remove fenders/black parts to check tire pressure.
Craig
SE OHIO
Cool:cool:
Craig
SE OHIO
You know, if you look close at the new pictures, it does look like you can't get to the stem without taking off the fender.
Joshua Caldwell
Fayetteville, NC
At 1200 pounds, just pick up that end and spin the tire :p
Joshua Caldwell
Fayetteville, NC
On the 17th I emailed the following question to Elio
I'm curious about the fenders. In a previous version the wheel cover matched the body color of the car, now it doesn't. Was this just a stylistic decision or is there an engineering reason for using different materials this time? Also, is the material used for that dark gray panel one that can be painted and is there a reason that I shouldn't have that section painted when I have a custom paint job done?
Here's the reponse I got today
You will have options when it comes to the color of the wheel covers!
