That pretty cool! Sounds like it is still in the early development stage. I get the impression that it could be retrofit to older engines.
Okay, I'm no engine materials expert, but with a leaner A/F ratio (I believe they mention 20:1), I'd think there would have to be some adjustments to the materials used in the pistons for sure, heads possibly, and valves due to increased exhaust temps (less 'quenching' with leaner A/F ratios), which IMHO limits a drop-in retrofit replacement for spark plugs. Maybe a ceramic, or at least some type of heat reflective coating on the aluminum bits in the combustion chamber would do the trick. Interesting article though.
