I wonder... The AC compressor has a clutched pulley so the AC can be disconnected from the engine basically, right? What if... Follow me here... the main pulley off the engine were also clutched and you had a motor/generator instead of an alternator? You wouldn't have to have special accessories. They could all work just as if the engine were turning.
You approach a stop and as your car slows (detected easily through software... shoot, my phone and my $12 OBD II can do it) below 5 mph, the engine pulley clutch disengages, the Motor/Generator (MG) kicks on to keep everything turning at an acceptable speed - AC, water pump, power steering, etc.
When you lift your foot off the brake, the engine pulley reengages which gets the engine spinning - adding fuel and spark will make it start right up..
The expense to this would be software that can sense slowing and brake pressed, the MG which is controllable by the software, and the clutched pully on the front of the engine.
That's all for an automatic. I still don't like that whole manual transmission set up. I don't shift my car into neutral at red lights or in traffic... ever. I guess I could learn though.
Sounds like it might do it. I'm just thinking of some of the horrible construction zones out in the interstates.
But, Oh well. It isn't a perfect world and as long as there is a manual kill switch.....
Last summer between Cincinnati and Louisville, between Louisville and Nashville, and between Dallas and Austin.
Yes, a start/stop system can shut off an engine while a car is moving, even with a manual transmission, quite a few systems do that. At the risk of repeating myself: this isn't current info.
