Jeff Porter
- Joined
- May 20, 2014
- Messages
- 2,086
- Reaction score
- 5,343
RA'd? Removed and Altered?
"Resource Allocation". Blech.
You can register using your Google, Facebook, or Twitter account, just click here.RA'd? Removed and Altered?
Who all is going for the Infinite Skyz system? Also, has anyone seen it in action face-to-face and would it be worth obtaining?
Oh, and the Configurator is up and running.
My understanding is they had on power steering is being considered as an option for Elio. That is a change. And it may not go the distance. But yes, it's on the boardds.I would question spending money for power steering. First of all, I've never even heard it mentioned as a factory or distribution center installed option direct from Elio. Second, if someone built an aftermarket version, it would cost big bucks and be a major pain to install. Third, have you checked the curb weight of the Elio? It is extremely light (part of the reason for the great mileage) and most of the people from Elio that I have queried online or at the touring display that I went to said because of the weight, power steering wouldn't be necessary at all. Because most power steering systems use power takeoff direct from the engine (like alternators, water pumps, A/C, etc.) that would rob power from an already small engine. I asked about the factory using electric power steering instead and again the Elio people said it wasn't even considered because of the lack of need per the above stated reasons. (low weight)
The old fashioned term was fired. Then they started making distinctions based on whether the company would pay the unemployment premium for the terminated employee.Altered? I think that's what we had done to the cat. Sorta the same process as when you get laid off, no matter what you call it.
Yeah, but @$1400 to $1500 for a wrap. I don't think so!There will be a Yellow wrap.
You are correct. #14761 is the only spot I have. i just didn't remember my spot number correctly at the time i was typing. Thanks for the catch!Scott, do you also have 14761 or am I mistaken?
