Is 84mpg Even Possible?
Adamant
West Coast
Paul Elio makes it seem like we should get 84mpg on the highway without having to do all that extra burdensome hypermiling stuff. Hope he's right.
Then if we do put in all the extra work to hypermile it, hopefully we can beat the 124mpg record.
Adamant
West Coast
The base C5 Corvette weighs about 3400 lbs ,LS1 360 hp can achieve 34 mpg cruising at 75-80 mph .Areo is a key part of the equation .I haven't. seen the estimated weight on the Elio
Jesus, that's actually fantastic! I'm really hoping we can achieve the 84mpg while moving at the speed limit of 70mph. If not, then hopefully it'll make it to at least the 70s (mpg) at that speed.
Muzhik
Iowa
I always figured "84 mpg" was a figure that would be obtained by using test vehicle driven by some skinny 100lb driver, etc. If it gets over 60mpg, that will be more than enough for me. This is considering that my 49cc scooter, carrying a 200+ lb payload (me), got around 70 mpg.plus or minus.
They don't check mileage that way.
Here's the link ------> https://www.fueleconomy.gov/feg/fe_test_schedules.shtml <---------
Smitty901
Some times the tricks they use to get a little more mileage are not worth it. Tires are an example some they use now have a little less roll resistance .
But the side walls are not very strong. and traction is not what it should be. I would rather give up a little and avoid things like that.
Rob Croson
Ohio
The base C5 Corvette weighs about 3400 lbs ,LS1 360 hp can achieve 34 mpg cruising at 75-80 mph .Areo is a key part of the equation.
Im not impressed. My Grand Caravan gets almost 30mpg when cruising on the highway. And its only slightly more aerodynamic than a brick! You'd think something as aerodynamic as the corvette could do better.
Put the Corvette engine in your van and then see what it gets.
Let us know and have fun winning all those 'sleeper at the stoplight' races.
