You can register using your Google, Facebook, or Twitter account, just click here.I'm looking to move to one of these:Looks like a nice add on, but maybe overkill for a light duty vehicle like ELIO. I'll go with the best filter I can get, and see how it does. Definitely will replace the pan plug with an easy drain fitting in case a cross eyed mechanic ever does the oil change.
Thank You big W.I think "BooBoo" may be talking about the Fumoto Valve.
The G1's have had engine oil drain plugs stripped by "overtorqueing."
Thank You big W.
Yes, but I like the ones that can't be opened with mischievous fingers. I had one that used an allen wrench, and I found this that looks Elio cool.
What makes you think the Elio oil filter will be hard to reach?Changing the oil in my Nitro isn't the problem; it's changing the oil filter; it's impossible to get to.
I'm thinking about getting a separate mount oil filter and do the same on the Elio.
Something like this: http://www.autozone.com/external-en...mount-kit-perf/153850_404956_0/?checkfit=true
For as bent and broken as I am, the easier something is to reach, the better.What makes you think the Elio oil filter will be hard to reach?
