bunchathrees
They'll paint the panels right there on the assembly line like gmail did... after installation for the body, before installation for the door, trunk, and hood.
Auto-corrected into a parallel universe.
You can register using your Google, Facebook, or Twitter account, just click here.They'll paint the panels right there on the assembly line like gmail did... after installation for the body, before installation for the door, trunk, and hood.
Thanks. Fixed it.Auto-corrected into a parallel universe.
That's a 3D render. Not a photochop as photoshop ain't nearly that good!The headlight caught my eye. Is this a real panel or photoshop from the P5?
the headlights in this rendering suggest EM is considering going to a dual low/high beam projector unit, rather than the single low/high beam in the P5 (compare with photo of the P5 below):
No posting for you! (in my best Soupman voice)I just tried posting this and it wouldn't let me!
The rendering doesn't show a yellow lens at the back for the running lights, like the P5 has. The second light in the rendering may be a yellow running light that has a yellow bulb, instead of a white bulb with a yellow lens. I'm good with that. The prominent yellow lens would look awkward against certain colors of paint. It makes everything look much cleaner. Or it could just be that the rendering doesn't model the yellow lens, but that doesn't seem likely.the headlights in this rendering suggest EM is considering going to a dual low/high beam projector unit, rather than the single low/high beam in the P5 (compare with photo of the P5 below):
