Dragonz
Salt Lake City, Utah
With the configurator, Do you think there will be an option to customize the wraps? If we wanted to put on a custom image or so. I'm fine with like a 20% increase, I just don't know how feasible it would be
Dragonz
If we are dreaming, I'm hoping that there will be an option for multicolored exterior lights! Light up the night sky, and maybe have laser pointers added on that activate at a click of a button to simulate a phaser shot! Of course they would be pointed towards the ground so as to not blind anyone...
The fittingly named "Dragon Lasers" might have just the product for you. It is a Yellow/Orange high-powered laser pointer, which gives you a visible yellow beam not unlike phaser fire.
I don't think the initial setup is going to be that granular; it will probably do the "Custom Wrap* " deal that will say something like "the standard one color wrap is $1,600; if you want to go beyond that you will have to work with the people that make the wraps and there will be an additional charge".
The whole idea of the Configurator is for EM to figure out which vendors to keep, and which to replace, or add on.
When it gets closer to the "place your order" configurator, it will have changed a number of times.
I think the initial change rate was going to be once a month (I think it will be twice a month).
Muzhik
Iowa
Apparently you know nothing about software development or system test procedures.
It is not a bunch of stoners sitting around their mothers basement.
Dude, lighten up! I've been around since people understood the phrase "The only debugging tool a REAL programmer needs is a soldering iron!" (That and "REAL programmers get their dinners from the vending machine!" and "REAL programmers wear hiking boots, in case a mountain should suddenly spring up in the machine room!", not to mention that real programmers remember when the machine room really held machines like tape punchers and card readers.)
Speaking of debugging and semicolons, you need to put an apostrophe in "their mother's basement" in order to prevent running into an infinite loop. ;)
