Found out a little more. All those fancy colors are wraps!
You can register using your Google, Facebook, or Twitter account, just click here.I believe that's correct. I know that there are lots of points along the upper frame members for power take-offs. How they're doing this I do not know. But if you're going to add cameras and extra lights and such, there must be a way to wire them ... so a pretty decent number of access points to the wiring seems like a good idea. I guess when you pull away the headliner you can see them.Does this mean there will be only one wiring harness for all Elio's so as to accommodate for any electrical options?
Your memory is correct. Whether that turns out to be the reality remains to be seen.I do remember information being mentioned on this forum, that there would be electrical plugs every few inches, such that many options can be easily accommodated. But again, that's just on my memory and this was mentioned many moon ago. Will it be easy to request too many options such that the electrical system can't handle them all? Unknown.
They could have sub assembly harnesses too; the main harness would have an input/output plug and you plug in a harness that would do a different package in an area. Like under the hood, or by the dash, or even in the back of the car.I believe that's correct. I know that there are lots of points along the upper frame members for power take-offs. How they're doing this I do not know. But if you're going to add cameras and extra lights and such, there must be a way to wire them ... so a pretty decent number of access points to the wiring seems like a good idea. I guess when you pull away the headliner you can see them.
Do you have to yell? I have a headache.THE CONFIGURATOR IS UP ON THE SITE!
E-Series to be done & ready to test in June.............
