What happens if your throttle gets stuck and you can't stop the car? with a key I can turn it off.This was one of the features of my Volt that I was surprised I liked so much. No more fumbling for keys!
You can register using your Google, Facebook, or Twitter account, just click here.What happens if your throttle gets stuck and you can't stop the car? with a key I can turn it off.This was one of the features of my Volt that I was surprised I liked so much. No more fumbling for keys!
You still have an on/off button, don't you? The keyless Fords and Chevys I looked at did.What happens if your throttle gets stuck and you can't stop the car? with a key I can turn it off.
You might need some type of power down sequence if your driving over a certain speed though. You'd hate to wreck because the off button was hit accidentally.
Considering the throttle is computer-controlled as well, it wouldn't get "stuck". If the computer locked up or ceased functioning, then it would stop sending an accelleration signal to the engine. Most computer programming is designed to "stop on malfunction" as a safeguard against situations like runaway accelleration.What happens if your throttle gets stuck and you can't stop the car? with a key I can turn it off.
You can't flat tow the automatic. I use a tow dolly and since they Hyundai is front wheel drive no miles are added to the odometer.Jim H, I don't know how Hyundai connects to the odometer. If you flat tow it does it put miles on it?
The sequence is, press on the start button, and hold it in for at least 5 seconds. (The time varies depending on the make and model; some are less)You still have an on/off button, don't you? The keyless Fords and Chevys I looked at did.
Wireless key entry and start.
Access your car through your phone.
Good thing that these thing can't be used to steal a car....
If the cars become self driving, someone will hack the system and have the car drive itself to a designated delivery point or hack shop.Wireless key entry and start.
