Truett Collins
So...based on several forum member's comments...Elio Motors does not currently have a in-house R&D facility...which I find very surprising...
So here's just a small list of testing requirements necessary to bring any new vehicle to market...I'm uncertain how you can set final design parameters without a staff of engineers to oversee & coordinate vender design projects...someone must supervise component integration for the Elio Vehicle...
This is a very insightful comment quoted from another forum with regards to Elio prototype testing...
"With any new engine design...you have to do cold-soak followed by cold start tests, and hot-start tests, and high altitude, and combinations of the two, and wet weather, and freeze/thaw. And you have to do some testing at wide open throttle, and at idle, because they both have limiting conditions for engine wear. It takes months. And that's only the engine. Then there's the transmission, then there's the suspension and chassis, and the electrical systems, and the interior. You have to make sure the vehicle will survive salt-spray environment, and slush and snow, and desert sand, and rain. You have to make sure the ABS and stability-control systems work properly on pavement, and wet pavement, and gravel roads, and on snow and ice, and bumpy roads. You have to make sure the air bags don't fire off when they shouldn't, and do fire when they should.Than there's long term durability studies...actual crash testing has to be performed...etc...etc...etc...the list is long and time consuming."
So...without it's own R&D department...who is going to supervise such endeavors?
That becomes the problem "we have always done it that way" is the reason we have so many recalls on established vehicles.....
Just because "we have always done it that way" does not mean it is the best way to do things.
