wizard of ahs
The 135/80 15 is only for the rear...
The fronts are 175/60 15
You can register using your Google, Facebook, or Twitter account, just click here.You just made my day.The 135/80 15 is only for the rear...
The fronts are 175/60 15![]()
I believe you have it backward Wizard. 135/80/R15 tires are the fronts. 175/65/R15 for the rear. Slightly wider for a little larger contact patch since there's only one. These are more than adequate for a daily driver. A lightweight vehicle like the Elio would hydroplane easily in heavy rain (like we have regularly in the Houston area). Wider tires would only exasperate that. You could end up with a vehicle that would be undriveable at anything over 25 or 30 mph.
Duh....my badI believe you have it backward Wizard. 135/80/R15 tires are the fronts. 175/65/R15 for the rear. Slightly wider for a little larger contact patch since there's only one. These are more than adequate for a daily driver. A lightweight vehicle like the Elio would hydroplane easily in heavy rain (like we have regularly in the Houston area). Wider tires would only exasperate that. You could end up with a vehicle that would be undriveable at anything over 25 or 30 mph.
