- Joined
- May 6, 2014
- Messages
- 1,747
- Reaction score
- 5,007
The device is a oil heat exchanger, used to control the oil temperature during engine testing.
Welcome to the forum
You can register using your Google, Facebook, or Twitter account, just click here.The device is a oil heat exchanger, used to control the oil temperature during engine testing.
It is suppose to be dyno tested January 28,29. Does this mean it has never been dyno tested before and these are the only times? This seems short. Is this when they slowly remove the oil and run it to destruction? They can't have their ceremonial "First Start" if the engine is destroyed unless they have multiple engines.
I wonder if the Feb 6 "First Start" means the end of engine testing. I suspect it does. It is embarrassing to celebrate something that later does not work out.
I park mine over sheets of cardboard. My drip pan isn't large enough to protect the entire area that leaksYour car engines are so oil tight you park them over a brick floor?
The only thing I park mine over is a drip pan.
Notice the cast oil pan on this engine like the Elio?Ecoboost 3cyl has something that looks similar
buy it at PeP boys- they'll get to know you!!Use one like this for your Ol' Drippy. They make bigger ones too I have one in the garage just incase but my ride doesn't leak even @ 180K miles
How much?Use one like this for your Ol' Drippy. They make bigger ones too I have one in the garage just incase but my ride doesn't leak even @ 180K miles
