bunchathrees
Hi Suzymic. Welcome to the forum. Post #2 in this thread has a guestimator which should help.
You can register using your Google, Facebook, or Twitter account, just click here.Sooo... either you're going to be living in your car, or your car is going to be living in your house?I'm hoping before May 2017...that's when my lease is up!
Welcome to the best site all Elio, as you graze, you'll notice a great many folks with skills directly related to producing this vehicle, Elio has in fact been off the pot and doing it's business for some time now. When you see a video of the line, much will have happened- for sure when production begins the publicity/news it will generate will become common knowledge, the incentives will no longer be necessary, and when you write your check you might be waiting on the back-end, as long a time as many on the front. We each have to decide the level ($) of commitment we invest in this project and timing.I find the Elio quite fascinating, but 'prototypes' have been kicked around for a few years now. I would buy one without hesitation, however, I'll write the check out when I see a video of a production line actually making cars. It's time for Elio to do its 'business', or get off the pot.
Welcome from Seattle, moved out here last year to be with my newborn grandchild- Lived 13 yrs just up the road in Delray Beach. I'm hoping it's your car lease, and not your home!, BTW, When the stores are in place, you'll be as close as they get- Ft. Lauderdale has been one of the selected store locations !!I'm hoping before May 2017...that's when my lease is up!
I was wondering if we had information on the planned rate vehicles will roll off of the line. I am holding a reservation number ($1K-all-in) in the eleven thousands. Would my car emerge on day 51 or day 137? Curious.
Elio Production goals for startup of production.
The Shreveport, La plant has two production lines. In the beginning there will be Camau employees as well as Elio employees working together to run production. Camau is the supplier of robotic equipment used to build automobiles and is used all over the world in the Auto Industry. As such it makes sense that they will lead the production lines and teach Elio employees. Eventually the Camau employees will not be needed and the production will be run by Elio employees. Production is to progress in 45 day stages as follows.
1st 45 day cycle / one production line is to be run by Camau employees with Elio employees assisting and learning. Production is to be 70% of line capacity and will produce 350 Elios a day.
2nd 45 day cycle / one production line is to be run by Camau employees with Elio employees assisting and learning. Production is to be 100% of line capacity and will produce 500 Elios a day.
3rd 45 day cycle / Both production lines will run with Camau employees and Elio employees. Production is to be 70% of line capacity and will produce 350 Elios a day for each production line for a daily total of 700 Elios a day.
4th 45 day cycle / Both production lines will run with Camau employees and Elio employees. Production is to be 100% of line capacity and will produce 500 Elios a day for each production line for a daily total of 1,000 Elios a day.
Using these goals the production numbers should look like this.
1st 45 day period.... 350 Elios a day times 45 days = 15,750 Elios total
2nd 45 day period.... 500 Elios a day times 45 days = 22,500 Elios, for a total production since startup of 38,250 Elios
3rd 45 day period.... 700 Elios a day times 45 days = 31,500 Elios, for a total production since startup of 69,750 Elios
4th 45 day period.... 1,000 Elios a day times 45 days = 45,000 Elios, for a total production since startup of 114,750 Elios
Production to be 1,000 Elio a day from then on.
While that may seem a lot consider that recently a TV documentary showed a car factory producing a new care every 90 seconds. And the Elio has only 1/3 as many parts as the average car.
I've heard 2 shifts for sure and 3 shifts only if it is necessary to meet demand.IIRR he also said, one shift then 2 shifts then 3 shifts for production.
That could be true, but they usually don't call those workers 3rd shift; they would be something like maintenance shift and have a lot fewer workers than a normal production shift.I thought the 3rd shift was reserved for maintenance of the assembly line.
Ty would know.
