Elio Reservation Map And Survey
Gizmo
Virgina
H Ray. Did you contact elio about getting your SIL? We can not help you. And as far as you not being on the map! Elio is not in charge of the map making. In fact they refuse to give that information out at all. And rightly so because they have no business to do so. The only way the volunteer elio map makers know what to put on their maps is to search the elio forums and have the information given by the participates. The map belong to the map maker and he shared it. He is busy and unable to update it at this time. When he gets around to it, it would be helpful if the new people provide the information. I created the OHIO elio enthusiast map on google maps. It took long hours and I sure wouldn't want to read somebody complain about not being on it.
https://www.google.com/maps/d/edit?mid=z9fYDRqGfww4.kluU_cKDKiwA
Lilly.... if you can post a link to your google spreadsheet, I can incorporate that date into the overall data.
Gizmo
Virgina
Since Goofyone is no longer doing this......figured I'd take it up.
Yay! Figured out how to import the spreadsheet to google maps.
So now that I've hurt my head figuring this out..... if you'd like information changed for your entry please let me know.
Well hells bells!
Now I can't import the data to map. Tried splitting it up...no dice. Will continue to try some different things.
Gizmo
Virgina
Had to simplify the form and the spreadsheet. Also came across another list of people with production numbers....and merged them with my spreadsheet. Talk about a lot more dots!!!!
Gizmo
Virgina
If I can get to the response file/list I'd be able to. But the only merging I'm doing outside of those who fill the form is the ones with production numbers. I may have to cut out the ones in our list w/o production numbers eventually.
Gizmo
Virgina
By that file name I'd say yeppers. Also found a couple of other much smaller ones which also had a much higher percentage of duplicates and errors.
