Elio Engine Block
The longer stroke has a very specific application on the Elio
Gonna be a bit long winded, but work with me here.
I need to start with the aerodynamics (I'll get to the point, I promise)
The Elio has roughly half the drag of the 1996 Geo Metro (5 speed manual 1.0 3 cyl), a car that is commonly used for comparison.
This is very important.
Let's Say:
Elio at 30 mph has 1 unit of drag
Geo Metro at 30 mph has 2 units of drag
The units are unimportant for this argument, measure them in lb or kg of resistance if you will.
Double your speed and the drag increases by 4 fold (use the K = ½mv2 if you must)
Elio at 60 mph has 4 units of drag
Geo Metro at 60 mph has 8 units of drag
So an engine designed to be efficient in a Geo Metro at 60 mph (with a specific gearing, and stroke) would actually be LESS efficient in an Elio
(measured in thermal efficiency)
This is where the length of the stroke of the piston comes into play.
Definitions:
Torque: power per impulse
Horse Power (Watts or Kilo Watts): Power per impulse multiplied by rate of impulses (RPM is a factor here)
A short stroke engine will produce less work per impulse but typically make an engine that allows a higher RPM with the same technology.
The power curve will show less HP at the lower RPM's but, due to the higher RPM, it will produce more HP at the high end.
A long stroke engine will produce more power at lower RPM's helping acceleration but be limited on the high RPM's thus limited on the rated HP.
Most drivers rarely make maximum horsepower which is measured at best rate RPM AND open throttle.
This brings me back to aerodynamics.
The Elio aerodynamics require less work to be done at speed. This allows a longer stroke engine to provide good acceleration without the NEED to have additional HP at the higher end. Thus 55 HP may seem paltry, it's actually sufficient due to the power curve of the long stroke engine.
This would actually explain the drop from 65 HP to 55 HP during the development of the engine.
Keeping this in mind, it is likely that the Elio will actually be "peppy" and fun to drive opposed to the sluggish nature of the Geo and more modern Prius C
Stay tuned for our next lesson:
A longer stroke does not necessarily mean a higher compression ratio.
55 HP paltry? Back in about 1980 I built a car that only had 19 HP. The car weighed a little over 1400 lbs. and got 70 -75 mpg and could hit 65 - 70 mph on level ground. A little weak on the 0 to 60 times but driveable. The best part was being able to drive to work 6 weeks on a tank of diesel. Torque is far more important than HP.
Many see the HP rating as the end all and be all and sneer at smaller numbers
Assuming 1250lb and 55 hp, the Elio comes in at 22.72lb/hp
And according to this:
http://en.wikipedia.org/wiki/Power-to-weight_ratio
Is about the same as a Ford Focus 2.0L
Frankly.... not bad for an economy car..
Smitty901
Torque moves my 1100 pound HD loaded down up the mountains operating at 2000-3500 rpm most of the time.
HP sets the 1/4 mile speed record.
All I need to the ELIO to do is get up to traffic speed at a rate better than the peddle car and hold Highway speeds.
WE7X
New Member
Issaquah, WA
Hope to start a technical discussion on what we can see so far from the picture of the casting.
Block ,head, valve cover and waterpump.
Some time ago, after seeing a picture of the basic shape and design, I asked the teck folks at Elio if this 3 cylinder motor was related to the Suziki car motor, also used int the GEO Metro if I am correct.
The basic response I got was that it was that it was 'based' upon that motor. Obviously a fair amount of rework and modernization, but the basic bones seem to be from that motor. It was a reliable motor and produced great fuel economy in it's day, and ones in good condition are still seen on the roads with a lot of economical miles on them.
Rod J
Issaquah, WA
Hog
Not trying to make any point or draw any conclusions. Just trying to understand the IAV connection, since IAV openly advertises - " We provide our clients with production-ready solutions for the entire vehicle." - They do not build production engines, they do the R&D so someone else can build them. I am asking who is going to actually be producing the engines after IAV is done with design and testing?.
Once IAV is done testing and clears the engine for production Elio Motors will be machining and assembling the engines themselves in the Shreveport plant. I am sure they will receive support in this process from IAV and Comau engineers.
Division 5: Power Train — In addition to the traditional four divisions of a manufacturing assembly plant, Elio Motors is very unique in the auto world as we have a fifth division — Power Train division. Typically power train plants are built to support multiple vehicles that utilize the same engine. Since Elio Motors is dedicated to one engine, our ability to build it onsite helps tremendously with quality, delivery and cost objectives. All of which are a critical strategic processing advantage.
http://us6.campaign-archive1.com/?u=24b371802c83d81776b06aa68&id=727e582c73
Elio Motors will likely use a commercial foundry to provide the raw castings. The prototype engine castings have been produced by Grainger & Worral. We have not yet been told who will produce the production castings.
http://us6.campaign-archive1.com/?u=24b371802c83d81776b06aa68&id=c1dea37f20
wheaters
Mainly elsewhere
It is!
All other things being equal, the torque increase on a long stroke engine comes from the larger "throw" of the crankshaft, giving a longer lever arm for the piston to act upon. The downside is that it won't rev so high as a short stroke engine of the same cubic capacity.
The closer we get to the diesel engine (long stroke + high compression + tall gearing + wider open throttle + low engine RPM), the more efficient the engine will be. This is how Suzuki got 55 to 60 mpg from G10 engine fitted to the Geo Metro / Suzuki Swift over 20 years ago.. Elio are going further still (literally) with lighter vehicle weight, better aerodynamics, less tyre drag, all of which allow taller gear ratios, resulting in excellent mpg..
ehwatt
KY
It is!
You are a clever bloke. I always thought torque is for the real world, horsepower for race tracks.
Back from under dust and cobwebs, I seem to recall that torque x rpm / 5252= hp (SAE).
