- Joined
- May 6, 2014
- Messages
- 1,747
- Reaction score
- 5,007
IAV Engineer talks about Elio engine
So, we have an answer to the "compression ratio" question: current target is 10.5 to 1...but they might "try" 11 to 1.
You can register using your Google, Facebook, or Twitter account, just click here.IAV Engineer talks about Elio engine
Just so you know...
This thread is about the elio engine block..
Would be nice to keep this on topic.
Do have any thing to contribute about the topic being discussed?
So, we have an answer to the "compression ratio" question: current target is 10.5 to 1...but they might "try" 11 to 1.![]()
In the video,(forgot name) the IAV guy, stated that it would be designed to use "low octane."Now this is the first numbers I have seen. It is pretty much understood that the higher the compression the higher the octane fuel is required. It is generally excepted that once you hit 10 to1 that 91 is needed to prevent pre or early non spark induce dentition. Simple way to put it stop the gas from firing on compress and heat alone. This is something we deal with on some motorcycles. You can tune it out to some degree there is wiggle room. but not much with out other effects on tune and performance. Also once you get to 10 to 1 it gets hard on starters and batteries, It is the reason starting in 2011-2012 all 103 HD engines come with Automatic compression releases. Added cost but necessary.
That is what happen to the Smart (dumb) car. It requires at least 91 octane at a much higher price, that wipes out a lot of the fuel saving.
At 60 cents or more a gallon you can afford to lose some MPG to get back to 87 octane.
This should also necessitate a stiffer valve cover which will be less prone to warping and leaking oil. My experience with similar engines has been one of constant oil seal issues. Hope that won't be the case with this one.Indeed. Volvo for example, has been using the cam cover as the upper cam bearing for years; http://www.atthetipwebs.com/technologyinstructions/volvo/S70/PICT7968-Small.JPG
It makes for a stiffer assembly as the cam cover is a bearing cap girdle at that point. No cam flex happening here.
IAV primary shareholder is VW. No production engines as of yet.
"...In June, the supplier added a location in Auburn Hills, MI, which includes capabilities for hardware-in-loop testing. More than 15 people occupy the office, and headcount is expected to reach 25 by year’s end. The supplier plans to grow this number to 50 in 2014.//.."
"...This year, capacity utilization is down to about 85% because of a wider range of customer projects that require more setup time. While last year’s focus was on diesel, this year’s work in the test cells is split almost evenly between gasoline and diesel projects, the supplier says...."
Mostly geared as an R&D testing facility.
Currently list 115 US employees on LinkedIn
"..The U.S. subsidiary grew stateside on the backs of its German owners. Volkswagen AG owns 50 percent of IAV, Continental AG holds 20 percent and Schaeffler Technologies AG & Co. KG 10 percent. .."
IAV just does R&D, they have no production engines released. The Elio may very well be the very first one, providing that IAV actually makes it, but why would they when VW is the 50% shareholder?
Just wondering.
