Anyone Know How Big Of Tire We Can Stuff Under The Back?
Lil4X
Houston, Republic of Texas
An interesting comparison of the 135/70-R15 and the 135/75-R15 tires on Tacomaworld.com:
The dimensions of the tires gives you a better idea of how they will scale with the car - and there isn't a whole lot of difference between them. I'd opt for the slightly larger 75-series tires if for no other reason than to gain a fraction of an inch of sidewall that would, in theory at least, provide a tiny bit more compliance.
ecdriver711
Would this be the difference between front and back or just comparing the two sizes?
the two front tires in possible sizes. the rear will be wider than the fronts
We are not sure if the rear will be wider than the front or not. It has been discussed both ways at times. Just one of those details that are TBD.
My guess is that EM does not want to use a different size for the rear, saves money to only have one tire all the way around, however we will see how it all plays out. My guess is that testing will be the determining factor.
cortsdad2
SLC, Utah
Most people likely would not want to outfit the Elio with wider tires for MPG reasons however for those interested in looks or handling this should be fairly easy to accomplish on this vehicle. Except for the easy to replace stock enclosed fenders the Elio front end should be able to accommodate fairly wide tires since bodywork clearance will not be an issue. The rear tire size will likely really only be limited by the design of the swing-arm as there should actually be plenty of room under even the stock rear fenders to place a much larger tire. I am sure people will engineer aftermarket swing-arms to accommodate some fat tires back there. :cool:
"some fat tires back there" I think there will only be room for ONE! LOL!
charchri4
Sunny SW Minnesota
Well the good news is they are designing the car for a 22 1/2" tire so even though that is pretty short it leaves open several good options in the 195 to 225 range for tires. I hope the bolt pattern is 4x100!
