That's what she said.Or just pull it in far enough to reach the oil pan and filter. No need to go all the way in
You can register using your Google, Facebook, or Twitter account, just click here.That's what she said.Or just pull it in far enough to reach the oil pan and filter. No need to go all the way in
She never said that!That's what she said.![]()
with a stop to prevent the rear wheel from "dropping in", ride over as a normal vehicleYou won't be able to get your oil changed at most franchise oil and lube garages either. The pit is in the middle of the vehicle track, right where the rear tire is.
Voted BEST answer! (by me), yes just stop once the FE is over the pit. It helps to be FWD doesn't it?with a stop to prevent the rear wheel from "dropping in", ride over as a normal vehicle
Where I live, we don't have a whole lot of those "pull-through" car washes -- they take up too much real estate. We usually have the ones where the machine goes around the car. If the front wheels are far enough apart that they can trigger the sensors (where you drive forward until a light goes on to tell you to stop) then you can use one of these automatic washers; otherwise you'll have to use the self-serve wand wash.I hope the E Build testing includes running at least one E series through a car wash to see if it survives the test or can even track through a typical auto wash. Crap, I'll probably have to driveway wash the Elio.
Talked about this with my mechanic. Again, most places don't have pits; they have hydraulic lifts -- makes it easier to work on multiple cars if you don't have to climb in and out of a pit. You move the lift pads so they are under the places where you put a jack to raise the car to change the tire, then lift the car and go to work. As someone else pointed out, a 2x6 under the rear part will fix that.You won't be able to get your oil changed at most franchise oil and lube garages either. The pit is in the middle of the vehicle track, right where the rear tire is.
You know perfectly well that I have a pending copyright on EATME, but happy to let the newly formed Elio Association of Testers, Mechanics, and Enthusiasts use it as I will certainly become a charter member. My EATME T-shirt suddenly becomes more versatile to wear to the monthly meetings of both groups.Something just occured to me... What if we formed our own "business", then became a "fleet customer"?
However many fleet E's we can get, we have delivered across the country to different areas based on Member population density. All the members who pitched in to purchase the fleet get on the map, and each member gets to drive the fleet car for a set time before handing it off to the next geographically-nearest member. Once our own E's start to be delivered, we auction off the fleet cars (either to members or the general public) and the proceeds are divided among the rest of the members.
I'm thinking we could call it something like "Elio Testing Authority" (ETA for short). Or maybe "Elio Association of Testers, Mechanics, and Enthusiasts" (EATME)
I had considered that. One thing it could do is remove the PR politics that EM has associated with selling 'advanced release product'. And also allows the higher price tag, EM not even having to disclose the price if we get in on the 'testing-partner' wagon for it.Something just occured to me... What if we formed our own "business", then became a "fleet customer"?
