Trusting
I'll go out on a limb and predict that after the Elios hit the streets there will be a company or companies that will start offering all kinds of accessories. Some kind of luggage rack will be among them...
You can register using your Google, Facebook, or Twitter account, just click here.I wouldn't place anything I cared about on the trunk lid of the Elio. No reinforcing, light weight hinges, light weight lock (if any) ... you could DIY all of that, I suppose, though the hinges might be a challenge.Mike, I have a set of trunk lid bags for my Miata that was made by Atlantic Designs. I don't think they're made any more, but something similar should work with the Elio. Appropriately sized, and one above the other instead of side by side like on the Miata, they should work handily. (Oh, FYI, they were waterproof and came with a mat to put under them to protect the paint.)
That is part of why I said to attach the mounts to the frame structure; good solid mounting point. From the pictures we have, there are a lot of good frame access points.Imbalanced weight in saddlebags can be a nuisance, but it isn't a serious problem. Just put a bit more weight on the opposite stirrup and you'll be fine until you can stop and readjust.
Seriously though, wouldn't it be better to bolt the boxes directly to the frame? That way there's no risk of things shifting or losing luggage regardless of the weight distribution.
It seems to me that with externally mounted storage the Elio could get overloaded quickly with two on board. With only one it would probably be alright, but then you could put the cargo in the back. A trailer sure seems like a good solution.That is part of why I said to attach the mounts to the frame structure; good solid mounting point. From the pictures we have, there are a lot of good frame access points.
Bringing back this concept for a second; this would actually be a pretty simple aftermarket product for the Elio. Thanks to the panel-on-frame construction, all you would need to do is replace the roof panel (and possibly rear quarter panels) with an aftermarket panel in this design. It could even be made to use the factory trunk lid and hardware for the rear hatch
It's more than that; there are also two frame pieces that surround the opening for rear strength.Bringing back this concept for a second; this would actually be a pretty simple aftermarket product for the Elio. Thanks to the panel-on-frame construction, all you would need to do is replace the roof panel (and possibly rear quarter panels) with an aftermarket panel in this design. It could even be made to use the factory trunk lid and hardware for the rear hatch![]()
nice, I'm glad they moved on from only the green painter's tape, Do I see just a hint of Yellow???This pic from the recent Elio blog clearly shows how small the trunk is, especially in the rear, If you will forgive me, I like my design better....
[Broken External Image]
