AJ Maxey
The top hose is the upper radiator hose, and the hose beneath that is the lower radiator hose.Like the 2 upper radiator hoses? I'm confused - but that's not all that unusual.
You can register using your Google, Facebook, or Twitter account, just click here.The top hose is the upper radiator hose, and the hose beneath that is the lower radiator hose.Like the 2 upper radiator hoses? I'm confused - but that's not all that unusual.
Two "top" hoses. One going to each side of the tank. 3rd hose going to lower right.The top hose is the upper radiator hose, and the hose beneath that is the lower radiator hose.
Three full size hoses going to the radiator, a cut off wire sticking up in mid air, and a myriad of hose clamps in the middle.Two "top" hoses. One going to each side of the tank. 3rd hose going to lower right.
It's still in the "In n Out" phase of fitting; when they're happy with how everything fits and works, it will all come out / off and then off to the paint shop.Three full size hoses going to the radiator, a cut off wire sticking up in mid air, and a myriad of hose clamps in the middle.
Are they going to show this thing at the LA auto show?
Is this thing called "prototype" or "kluge"?
(And, how much does this thing cost?)
I really doubt they would let the frame be considered complete without some kind of coating/sealer on it.
The frame will probably be ground smoother (not show car molded and blended just the slag and over welds ground down) primered and either painted or have something like Line-X on it and all the body panels will get prepped and painted.
Once that's done, reassemble and road test it before putting it on the trailer.
So all of those "make work" clamps and hoses will be purdyed up.
Yes, there is.There is no AC condenser installed yet.
Where do you see a condenser?Yes, there is.
I think the "third hose" goes to a pressurized,with cap, overflow tank,like the type used on a Mazda 3.
