Pep Boys
Tire repair kit is ok. As long as there is enough tire left to fix. And the bead has not popped off the rim. Well, I can take care of the bead off the rim but it scares the pants off of people.
Ahh...The old starting fluid and match trick. ;) Definitely a 'sketchy' procedure, but necessary if you're out on a trail somewhere.
DanS
Oklahoma
Done that with a rope and hand pump. Definitely a good field (bush) technique.
Hopefully before too long we won't have to worry about flat tires.
http://www.lltek.com/PRS_bin/PRS_77_AudiMichelin.htm (may have to copy and paste into browser)
No more flats! No more TPS system! The ability to customize the performance of each tire for horizontal and vertical stiffness depending on the kind of ride you are looking for. I CAN'T WAIT!
CheeseheadEarl
Get used to waiting. Your link is 10 years old, and the Tweel is still only available for skid steers and I think John Deere zero turn lawn mowers.
that article was published just over years ago .... I wonder what happened to it
