MajorXx
with the dual valve timing I suspect the rpm for a given speed will vary depending on which valve timing the Elio's computer is running
Not unless it changes gears as well..
You can register using your Google, Facebook, or Twitter account, just click here.with the dual valve timing I suspect the rpm for a given speed will vary depending on which valve timing the Elio's computer is running
Thanks for the great video. Looks like that would satisfy those who want a very fast Elio. I'm guessing the cost is way beyond the means of most of us who will be buying the ElioMaybe in 2017 Elio will just install this light weight engine in ELIO only 138 pounds.
