I think it would be pretty safe to believe that the number one guiding principal in the design and build of an Elio engine centers around gas mileage .... they have also made a point of saying the power train will be built to deliver 100 mph ... those to aren't mutually exclusive but are highly dependent on the transmission gearing .... high mileage accompanied by high speed aren't in harmony with high pulling power .... in this case I'm referring the pulling power necessary to maintain road speed going up mountain grades .... does anyone have any info on how they plan to balance the need for high mileage/speed with the the need for power necessary to get up a hill without having to pull over into the slow lane
Good question Jim!
The engine will be using a dual lift or shifting hydraulic bucket on the intake. There are three lobes per intake which allows for two cam profiles each with different intake valve lift and timing. This allows for high and low lift based on engine RPM and load demands. So basically more power when you need it and more efficiency when you don't.
This has been discussed in the Engine Valvetrain thread: http://www.elioowners.com/threads/elio-engine-valvetrain.2305/
