Airhorns on my Miata in a college town is a necessity. It's hilarious to watch the ones who are TWW (Texting While Walking) jump back on the curb when you lay into the airhorns and you never see their knees flex. :D
You know they aren't loud enough if they don't drop the phone.........
Frim
Warrenton, MO
I was thinking the "D" would be right at the wheel knuckle... It would lift the lower A arm and wheel directly. With the tire completely flat, it looks like you'd just need about 4 -6 inches of lift. The suspension won't droop because you are picking it up as well.
In fact, a long letter "J" type of jack where you basically crowbar the car off the ground should be fairly easy... put the short end under the knuckle of the A arm and step down on the other end. If the short end was 6" long and the long end was 24" long, you'd have to press down 130# to lift 520# (approximately) and THAT should be enough to lift any of the 3 wheels.
how much pressure does take to press the "call" button on my cell phone?:D
Sure, that's easy enough. For me, I'll just pop the tire off, get it fixed and pop it back on. That'll be faster than having AAA come out, put you car on a flatbed to take somewhere till they can find a tire to fit it.
Eliosio
TN
I would like to see Elio have as an option the heated windshield VW has developed that uses silver and no wires to heat the glass. It will also reflect 60% more heat in summer than tinted glass. The mass quantities Elio would buy could make the option about $100. I would opt for that in a heartbeat.
