Maybe we should be sending bug reports to Elio
Or maybe they're lurking around here anyways. Who knows?
You can register using your Google, Facebook, or Twitter account, just click here.Even in my advancing years, I can probably tell when the emergency brake is on. However brake pressure problems might not be so obvious and a warning light saying your brakes are about to f*** you over is probably a good idea.Some of those can be moved to the switch that controls them such as the Traction Control; the E Brake, if you can't tell that lever right behind the shifter is down, I don't know if a light would help
And as for the warnings for low oil, or overheat can be added if I'm not able to reuse some of what is already there.
But as always, you can have anything you want <no not at Alice's> for the right budget.
In that case, are you sure you really want to know?Even in my advancing years, I can probably tell when the emergency brake is on. However brake pressure problems might not be so obvious and a warning light saying your brakes are about to f*** you over is probably a good idea.
That's some Escher reflection there. A reflection off the roof when looking straight down wouldn't be seeing a horizontal view.Rotate the rendering so you are looking down at the top and you can see the reflection of a building. I am thinking Paul Elio's summer home?
[Broken External Image]
Unless the Elio is rotating in 3D space and the background is static.
