Myelio.me Is Up & Running
Sweet! Now another choice to make...
Oh, there's more that that; a bunch of different style pointers, in different colors, flat or curved glass (although that may not matter) LED lighting in the gauge, turn signal/high beam LED's; and the possibility that I can get it pre-built to be a straight out, swap gauge faces, wire, reinstall, calibrate, and go.
Plus over 300 installers nation wide. Price is still in discussion, but minimum is $650.00
This is the only time, and part of my life I'm in touch with my female side; I know how to shop and dig for the best deals :becky:
No high maintenance here.
Frim
And I've finally found the direct replacement for those big grey / silver "disks" on the bottom
It is the first 3 3/8" combo gauge I've found.
The Elign "disks" are the same size so it will be a direct replacement.
Yes, they do have a matching Speedo/Tach
I don't know if they come in the reverse colors yet; I have a call into them.
Outstanding!!:victorious:
Jeff Miller
I'm not sure if anyone has posted this yet, but I was poking through the web resources on the configurator site and came across this image:
Looks like these are the renderings that are currently getting used for the dash
So that looks like a regular 1 DIN radio for a base radio. I also want the 200 MPH version although I can't imagine driving that fast :)
Clicks link:
$577.95
And that's about $80 more than the ones I found ($495.00), depending on what type of speedometer you want.
If you need an additional sender for the speedo it's $55.
I quoted $650 to include the tax and shipping, I'm not a reseller, but I do have a business license; you'd need a CPA to explain what I have to go through for the tax; plus I'll include a Elio specific sheet for the install).
For fuel in the AutoMeter you need to buy their sender unit, in the ones I found you order the gauge to match the OHM rating of your exiting sender, so wiring will be easier.
(I spent a LOT of research time, and phone calls to AutoMeter about them.)
Nice work Cross. I think it's only fair that you make a little scratch for all the time you put into finding these.
Oh don't worry; some of the best things in life are free; I'm not one of those :becky:
Plus, the first person that's going to get one of these installed is me. :thumb:
<Someone has to do the testing ;) >
Top
