You can register using your Google, Facebook, or Twitter account, just click here.Engines are so beautiful when they are clean and unused.
The Adams-Farwell firm's automobiles, with the firm's first rolling prototypes using 3-cylinder rotary engines designed by Fay Oliver Farwell in 1898, led to production Adams-Farwell cars with first the 3-cylinder, then very shortly thereafter 5-cylinder rotary engines
I didn't notice this before, but he said something important for aerodynamics. They are routing the exhaust to allow a full underbody pan. I'm really glad for that. You can tuck things all tight together under a car all you like, but it will never be as smooth as a full under-body. It will definitely give them a better shot at keeping their 84MPG. If they also add flexible baffles at the two suspension areas then I'd suspect they can actually beat their 84MPG requirement. JMHO.OK, not sure if I was the only one to watch this old Youtube video but it seems to answer most all of the questions being asked about the Elio motor. Direct from the IAV Engineer step by step. Yes it has an EGR, yes it is a timing chain, where the knock sensor is, etc, etc. Might be a good review for answers and additional questions. Crappy quality video but you do get the design and build info straight from the engineer that built it. Hope this helps......
Just to clarify I asked Jerome specifically about the underbody and he said the engineers are designing to accommodate it however whether this is an option or standard depends on how close they are to their MPG numbers. Basically if EM feels they are close enough without the need to spend extra money on including it standard then it will be an option for those who wish to maximize their fuel efficiency.
Fixed that for ya.Engines are so beautiful.
Does this thing have a timing chain or belt. I can't tell....
"Everything old is new again."Excellent video thank you for posting it! Interesting I did not know EGR was coming back to the industry. I need to read up on that.
Same story here: The old Insight was certainly not the first, but it has a factory aerodynamic underbelly pan under the engine and transmission. I have to remove a few bolts to drop it and do an oil change. Some folks made their own full-body under-pan (underpants?) and found it improves MPG, but not as much just the factory front pan (and deflectors in front of the wheels) and things like sealing the front grill. Elio could likely get most of the aerodynamic advantage with just a pan under the front.I can verify that .... there was also a brief conversation about how such a sealed underbelly would affect oil changes and such .... that point was unknown
