Sounds like the idea is about sensing when the rear end lifts in hard braking and applying more rear brake to prevent it from slamming that much MORE weight onto the front brakes which are already handling most of the job. plus keeping the vehicle more level will give it better braking traction on all wheels, 'stead of stopping in a nose-stand position with the tail in the air. Or am I missing the mark?kinda an unfair comparison really. the elio will only have the one break pedal so height sense valving will need to be used to balance the braking forces between front and rear wheels. the goldwing uses multiple pistons within the pucks, that are attached to the front and rear breaks, on three rotors. if i had a diagram to post it would explain a lot but that is not the system i would want installed on the elio, only the concept of differential braking, probably by a rear swing arm sensor, so that a rear seat pax would cause more rear wheel braking force than the driver alone.
