JF
- Joined
- Jun 28, 2014
- Messages
- 25
- Reaction score
- 67
Put a big fat front fender and some saddle bags on that and I will order one!................like the new Electric Harley!
You can register using your Google, Facebook, or Twitter account, just click here.Put a big fat front fender and some saddle bags on that and I will order one!................like the new Electric Harley!
I have no faith. Just so you know faith has nothing to do with my quote.Thanx Rickb but I have plenty of toilet paper. What I need, low, hunger for, are facts and sources for such. And no, I don't rely on faith. But I do enjoy watching the magic show some of you guys puts on.![]()
I heard an old Harley Biker say it sounded good! I can't use his actual quote! LOL This media statement:Sure they will. Once they get the high tech playing card in the sppkes perfected, so it still sounds like a '37 John Deere.
Yeah, agree about the unsprung weigts--for that reason I'm not a big fan of in-hub motors. I'd rather attach it elsewhere and get a pulley and belt drive combo.The hub motor in the rear sounds like a very fun project, as an electrical engineer I really enjoy playing with this sort of thing, however the issues I see are the addition of a large amount of extra unsprung weight located at the very rear of this vehicle which does not sound like a good idea in terms of vehicle handling.
This being said this is a relatively inexpensive platform for tinkering and I expect to see a lot of that going. I will enjoy watching people get creative whether it works well or not. I even have a few ideas for mods and even an engine swap when I decide to buy a second one.![]()
Wheelthang; go figure."Seeing that Elio Motors is not likely to raise its 200M by next year". Can you expound on where/how you cam to this conclusion?
This unit only weighs 75 lbs. Maybe the swing arm would have to be beefed up: which would add some more weight. The weight distribution would move back. As an electrical engineer....Is their a way to keep the motor from over powering the engine?
I don't see harley as doing anything as truly original as the Elio. It's not in their corporate genes. LOL Same for Polaris slingshot. The slingshot is nothing more than a $20k up sized hotwheel tricycle. LOL They have not even finished their web site. LOLSure they will. Once they get the high tech playing card in the sppkes perfected, so it still sounds like a '37 John Deere.
Modify for power, or modify for fuel efficiency. There are many solutions, depends on what the final intent of the modification is.The weight distribution issue can be dealt with much easier than the fact that it is 75 lbs of unsprung mass (weight on the wheel side of the suspension). The more unsprung mass you have the more that wheel assembly reacts to the road and with much greater force. With the hub motor we would be talking about somewhere around 100 lbs of total unsprung mass (complete assembly of motor, wheel, tire, suspension, etc...) bouncing up and down at the rear of this vehicle. Due to the light total weight of this vehicle it would extremely hard to dampen this much mass effectively making the whole rear end extremely unstable. I am sure we have some good mechanical engineers on here who could delve much deeper into this issue.
As Snick mentioned an electric motor mounted to the chassis with a drive belt or chain would likely be a much better choice for the rear end of this vehicle as this would eliminate the unsprung mass issue.
An automatic transmission should be able to keep up with the extra acceleration provided by the electric motor as long as you are not getting too crazy with it. You could likely use the output signal from the existing throttle position sensor, used by the drive by wire system, to send throttle information to the motor controller which would make for an easy to use system. It would likely take some tuning of the electric motor controller to get the throttle response just right but nowadays it would not surprise me if you could just have a tablet mounted in the cockpit to control and change the settings of the electric motor in real time.
What about a pair of front wheel hub motors?The weight distribution issue can be dealt with much easier than the fact that it is 75 lbs of unsprung mass (weight on the wheel side of the suspension). The more unsprung mass you have the more that wheel assembly reacts to the road and with much greater force. With the hub motor we would be talking about somewhere around 100 lbs of total unsprung mass (complete assembly of motor, wheel, tire, suspension, etc...) bouncing up and down at the rear of this vehicle. Due to the light total weight of this vehicle it would extremely hard to dampen this much mass effectively making the whole rear end extremely unstable. I am sure we have some good mechanical engineers on here who could delve much deeper into this issue.
