Speedym7
New Member
I went all in for $1000 on 8/18/2014When did you get your reservation number?
You can register using your Google, Facebook, or Twitter account, just click here.I went all in for $1000 on 8/18/2014When did you get your reservation number?
Experienced drivers have a higher measure of acceptance and on that end, it's kinda funny how you could go all-in for 3 ELIO 3wheeler without having drive tested it in different conditions (snow, gravel, crash worthiness, CG issues, 4 wheels vs 3, etc.) ??? US city freeways does not scare me at all...buying a car you've never tested is! There's always that element of risk on anything you do, what you drive and how you drive and believe you me, the untested ELIO will be subjected to the same brutal environment and if not used as intended (going faster than allowed, modifying the engine, etc.) one can get in a lot of trouble just like the cars you mentioned!It's because these 'specs' aren't your measure of acceptance.
Look, I want the suitability of the wheelbase because I've seen and felt what a failure from that is like. For example, I've seen a short wheelbase bronco spin like a top when he braked a little too hard on the freeway. Other dynamics due to CG are at issue too. After you experience it traumatically, you will up your requirements as well.
And RWD? Well ,no problem if you never encounter ice or snow or gravel. But I do. As an example, I rolled a VW bug on a gravel road because of the interaction between center of gravity and where the power was. The VW had other failures due to the RWD. Liveable ? yes, desireable? not as much. Could I have driven more carefully? Yes. Could anyone have made my mistake? Yes. It was just a bit too easy.
As for cash worthiness? All US city freeways are scary as hell. This matters.
An another thing, FWD has a heck of a lot more impact for a 2F1R than any common 4 wheeler, that just pure engineering.
I built a 2F1R-RWD vehicle. Several failures were visible. Take my word for it.
I also built a mid-engine sportscar-sleeper(4wheel). It was awesome. But the CG was 'just-right' for the power and placement. Good in the wet, never tried it in ice or snow.
On black-ice, I'll take the VW over the 911. And the Elio above both.
"On black-ice, I'll take my couch and the TV so I can check out all the wrecks I'm not in."On black-ice, I'll take my couch and the TV so I can check out all the wrecks I'm not in.
I've got a 914, three actually, none road-ready at present time. When my '74 was on the road it was quite the blast to drive, particularly on the curvy roads. Great on the highway too. I've heard, but can't confirm myself, that once you break traction in a curve, like on a slalom course, you're going to be taking a ride to spin city before you have time to react because of the mid-engine. Seen a few videos of guys losing it. Might try it myself when I get one running and there a big empty parking lot around!
The best handling car in the world mean nothing to a mechanically challenged driver!Yes, I have heard the things you mentioned. Swing arms are a classic issue. But not the reason for my personal fail. (I was not on a turn at the time)
And the VW was also acceptable (for most people) in a good crosswind, but not so much at high-speed plus a high crosswind. In this case the CG is behind the center-of pressure, which causes the problem. There are a number of reasons any Porsche (say a 911?) is better than a VW in a cross-wind. I've been a passenger in a 914 at 129mph in AZ. Passing a truck was interesting. I wouldn't try that if your VW could go that fast. I wouldn't try the 914 at over 160mph. The 914? sure. All three are below my threshold below 55mph in most any crosswind.
Again, it's your threshold that makes the call. As for the Robin and this one in the link below, no way is 120mph below my threshold.
https://newatlas.com/twike-5-pedal-assist-car/58899/
I would definitely trust the Elio above the Twike, or VW or Reliant at 120mph in any weather. I'd prefer the 911 at 120MPH.
I prefer my Atlantric at 120MP'G' (raw estimate) :-)
Also, how about we compare modern cars and not some old Bug or 914, that a modern SUV could easily out do today.The best handling car in the world mean nothing to a mechanically challenged driver!P.s. An autopilot might work for them....then maybe not! (Trying to manually drive it while set on autopilot
Same here but whatever it is, at 120 mpg it must be running at 15 mph or slower so is not really street legal!Also, how about we compare modern cars and not some old Bug or 914, that a modern SUV could easily out do today.
Also on a side note, I have wondering about this "Atlantic" and the only thing I can see as to what it is is a Mexican VW Jetta from the 80's.
