electroken
If the headlights don't come as LED's, I will replace mine.
At the base price they will almost certainly NOT be LEDs.
You can register using your Google, Facebook, or Twitter account, just click here.If the headlights don't come as LED's, I will replace mine.
Just get a spark arrester for it and they're fine.![]()
You can upgrade it by replacing the standard candle with a dual wick candle. You have to be careful with the three-wick candles. They may be regulated for off-road use only in some states.
Come to New Mexico or parts of Arizona where they have "Dark Skies" ordinances which restrict the amount of lights at night including street lights, porch lights, etc.Money. Buckets of money.
Most urban and suburban areas are so lit-up now that headlights are almost redundant. I live in the exurbs and every little intersection, bridge, and corner has a streetlight. The one-lane bridge right in front of my house is lit at both ends! Point being, I don't think Elio needs "exceptional" headlights, just "good enough".
I think the only way to make exceptional ones now would be LEDs. They are getting so cheap now that you can stack on all you need for very little money. Their tiny footprint, low power consumption, and low heat generation make them much easier to package. Where the buckets of money still have to go is designing the capsules and lenses to control and project that light. That is a big, big expense.
May be the "exception" where you are but you need to realize there is a whole nation out there and the majority of the land in this nation is not covered with concrete and asphalt.I'm sure you do. But you are the exception and not the rule now.
Elio has a limited budget and will do the best they can.
One note: If they were LED you wouldn't be able to upgrade them with brighter bulbs. OEM LED headlights are non-serviceable. If they "burn out", you have to replace the whole capsule for a tidy sum.
I'll try it. After 6 rounds of corneal surgery, my eye has the texture of a supremo pizza .... glare is a significant problem.For over 20 years I have dealt successfully with oncoming who do not dim their brights. I simply close my left eye when the lights appear and open it again when they are past. The protected eye "sees through" the blind spot created by the brights until the eye that was open recovers.
