Unless I'm not near a fueling station, I don't allow my gas tanks to get under a quarter of a tank. My reasoning is simple, the fuel pump is inside that tank and uses the gasoline to cool the pump!
While they "may" be better these days, running the pump when not submerged in fuel allows it to get a lot hotter. When you shut off your vehicle the pump goes through a "hot soak", meaning when it's not even turning, there's no way to disapate the heat it generates. (no flowing liquid in it) Premature pump failure, sometimes right then and there, is the result.
