And Now... The P5!
Thomas Maule
San Antonio, Tx
my first reaction to seeing the exhaust port below the fuel fill was one of concern .... given input from others on this I no longer have the same degree of concern .... could there ever be a problem, I think the answer is yes .... is a problem very likely, I no longer believe that it is .... the analogy of fueling a motorcycle makes sense to me
All the contouring lines on the car, and even the exhaust vent itself seem to be slanted in a way that would direct any fuel running down the side away from the exhaust port... so it may be a non issue in all but the most extreme circumstances...
[Broken External Image]
TCBronson
Hot Springs, Arkansas
I was thinking more along the lines of running out of gas and needing to fill up with a plastic gas can used for my lawn mower.
I will leave that up to Elio, or aftermarket guys... It's not worth it for me. I just want reflectivity to be seen in low lighting conditions. During the day I shall assume that you can see me for obvious reasons...
hearing about and seeing the ways folks handle such mods is really going to be interesting
Durk Jenkins
Dunlap Tn
I like everything they did including the exhaust outlet. I like the longer nose as well. In the pictures there appears to be a circle that maybe the gas door. I would hope they would consider having the gas door on the other side near the car door for easy fueling. Also away from the exhaust outlet, if gas dripped down it could be an issue or maybe hot exhaust tip near your legs may be an issue. Just a thought. Otherwise I like the blue too!
I agree with you about exhaust. It should be on the oposide of fuel filler like all vehicles are with a single exhaust.
Grumpy Cat
WI
Gear shift (And, I'd assume, hand brake) are on the right side. Kind of difficult to climb over them on your way out if there was a right side door.
I know with the Corvette C4, the parking brake was on the left side. It wasn't very pleasant to use though.
If they really wanted a right side door option, both shift and park brake are cable controlled and could be door mounted.
I don't see a need, but it is doable.
Fanciful thinking - what about a suicide passenger door on the right, driver door still on the left?
I can see how a parking brake can exist on the left side, but I can't see how shifting would be done from that side with the door.
That's it! That's the name for the car!
The Elio Dragon
That's the perfect name. The car looks like a dragon. I want to drive a car called a "dragon". Dragons are cool. Hasn't been used by any other company. Perfect. You win all teh Internets, Mr. WilliamH!
No offense meant to anyone...
But I hate it.
