The expensive part of building an engine these days is emissions certification. If you're going to build an engine for simplicity and economy there are a number of techniques that have emerged since the Geo's day, including superior metallurgy, precision casting, better induction and fuel management and far superior electronic engine controls. If you're going to build a "new" engine - even one based on a 20 year-old block, to build in volume is going to require extensive rounds of testing and certification. Let's do it once and be done with it.
Setting the bar at 84 mpg with a 55/55 hp/torque output was a lofty goal - and one that EM seems to be meeting. The Suzuki engine would have never made it. From a marketing standpoint, 84 mpg highway is a stunner - and it excuses a lot of lightweight design, odd, three-wheel looks, and tandem seating. Aerodynamics have to be a top priority to achieve that goal, and the final form is going to have to follow the needs expressed in the wind tunnel. That means no two-abreast seating to achieve a narrow frontal section, no saddlebags, trailers, luggage racks, or roof pods to disrupt the clean airflow over the body; even rolling down a window is going to have serious consequences to fuel efficiency. Hence, air conditioning.
Now, with that said, there is no reason several of these options can't be added at or after purchase. Just don't expect that 84mpg figure. What we often lose sight of here is that THIS Elio is designed as a single-seat commuter - with the capability of hauling a passenger and a small amount of luggage - a briefcase or two - that's it. It won't carry the family on a picnic, nor will it haul sheets of plywood for a home DIY project. It's not a sportscar in the modern sense - meaning something with track day potential. Elio will be fun, but within its limits.
