I like this 2000 Chevy the best.
I like the Kia Sidewinder. Most of the models have a severe looking taper to the rear as viewed from the top. It's a little off putting in some models but totally wrong in others. The Kia you did seems to hide the awkward rear wheel with tasteful scoops. I wonder if the Elio with a similar scoop set up to make it appear wider without totally killing the aerodynamics would look good.
Not that I really care about my own taste in the context of getting an autocycle produced, but, I think I like the JetSet as much as anything, even more than the Atlantric. But It can't beat the Atlantric for cd and cross-section. Anyway, those other two are definitely compelling.
The Kia, yes it takes advantage of some tricks. The dark panel at the back, similar to the Elio, removes the area from visual importance to the human perception. If the area is ugly, offset it in a different and darker color. It works.
Another trick, lighter things seem bigger than darker. Another, if something seems too tall, split it with a horizontal line, now you have two shorter things stacked up, darken one of them and now you have just one floating above(or under) another thing which is easily ignored.
Your choice of two-tone paint can do a lot of that, (Bell Areo!).
It's the classical art of impressionism at it's best.
