I am not for sure but I would assume there would be a semi-normal hub where the tire would bolt to. This would have a small stub shaft with bearings attached to the mono shock assembly.
Imagine a question mark turned up side down ? upper arm attached to an axel attached to the wheel. A removable skirt permits access to the bolted on wheel---functional and simple! RB
