Bill Gate's Opoc Engine Vs Elio's Iav Engine?
Adamant
West Coast
OPOC Engine: 2cyl, 100hp/100mpg
Bill Gates is helping to fund this motor. It will be built in China.
MORE INFO:
http://www.ecomotors.com/opposed-piston-opposed-cylinder-engine
http://fuel-efficient-vehicles.org/energy-news/?p=1048
vs
3cyl; 55hp/84mpg
Seems like it's gonna be super efficient, but I wonder how it stacks up to the OPOC?
The OPOC engine should go into production in China later this year or next. I wonder how these two engines will compare and ultimately if an OPOC engine could be put in an Elio vehicle? If so, I wonder what the hp/mpg specs would be then? Probably pretty extreme.
The OPOC links have the latest news over a year ago. Maybe it's failed to give the promised results???
I was thinking the same thing. I also failed to see a Bill Gates connection. I wonder if the engine had technical hurdles that they couldn't overcome. There is a lot of rotational mass in that little engine.
I thought this was promising back in the day: http://autoweek.com/article/car-news/inside-bruce-crowers-six-stroke-engine
It uses the heat produced by the engine to flash water to steam in a second power stroke. Water turns to steam at a 1,600 to 1 ratio. A side benefit was the engine was self cooling mostly. We waste so much energy heating up our engines and more energy cooling them back down.
Adamant
West Coast
Bill Gates is one of the primary donors to the project.
W. WIllie
Campo Ca.
The OPOC looks complicated, and expensive to build, for a "two stroke" engine. Most two strokes engines are slowly being banned in the USA. Especially for highway use. I don't think I ever read anything about the "size" of the OPOC engine.
Willie
