You can register using your Google, Facebook, or Twitter account, just click here.Whaaaaaaa??? I don't see where you're going here as it doesn't even fit into the conversation. EM says the engine will be capable of a max 60HP although it will be detuned to 55HP or less. Given there will be few if any aftermarket Hi Pro parts for this engine anyone who mods it to produce 75HP will have something highly unstable.
No body not even the big dogs back a vehicle that's been modified OUTSIDE of the manufactures control. You could go get Harley Davidson Hi Pro parts installed by a HD tech and they'd back it. They wouldn't stand for anyone else's parts though.
Yet you can use any maintenance items you want. The lines are drawn when you get to headers, cams, fuel injectors outside OEM specs, or anything that changes the computer. (just to name a few)It may or may not mean anything, but several years ago, there was a push by auto makers to claim that ANY aftermarket products used on their vehicles would/could void warranty. IE: oil filter, air filter... This was an attempt to basically shut out any aftermarket companies. The "Magnason-Moss Warranty act" (sp) was passed which states:..." Warrantors cannot require that only branded parts be used with the product in order to retain the warranty.[7] This is commonly referred to as the "tie-in sales" provisions,[8]"...
This basically says that manufacturers cannot make a blind claim that an aftermarket part CAUSED the component failure...they have to prove it. my 2 cents
A buddy of mine put a 302, bored out, into a Pinto.I think every car has been hotrodded at some point... even Pintos...
What I need to know is how much will I have to soup up my Elio in able to be able to pop the clutch while facing downhill sitting in reverse to do a rearward wheelie? The back end will already be pretty light...A buddy of mine put a 302, bored out, into a Pinto.
... The lines are drawn when you get to headers, cams, fuel injectors outside OEM specs, or anything that changes the computer. (just to name a few)
No need to.You may want to read up in it
