I believe you my have the heat thing not quite right, Alcohol burns at a cooler temp then gas, hens the less BTU s per gallon. The rubbing alcohol on the body to cool you down in the result of evaperative cooling, vaporizing is not the issue, its freezing that's the issue. All the moisture in the air can build up ice in the intake. A higher temp is not whats needed, it good heat distribution, and all cars control for that. The start on gas get hot and switch to a different fuel was mainly on old farm tractors in the teens through the 40s, ALL FUEL was what it was sometimes called, It was cheaper than gas but had less power and was dirtier to burn in your engine When i was in collage, 1982, we had to tune a lawn mower engine to run on alcohol, specifically 180 prof ever-clear. it wasn't that hard, we just made some carburetor modifications and it ran fine. As for another poster the RFS renewable fuel standards has not been renewed for 2015 yet{ yes 2015]
I think we actually are in basic agreement. Yes, alcohol has fewer BTUs than gasoline. Yes, the alcohol cools the body because of evaporation. Before a fuel will burn, it must change from a liquid to a vapor. This requires evaporation and heat is needed for this. This is why the carburetors set nicely on the intake manifold with hot water also running through the intake manifold. The carburetor and fuel were all kept hot promoting complete evaporation. To get the same complete evaporation of alcohol as gasoline, alcohol requires even more heat. When a liquid like alcohol evaporates, it absorbs heat and can become so cold, moisture will freeze. Heat is needed to keep the alcohol vapor above the freezing temperature of water so the freezing you are referring to, will not happen. Propane is another liquid that requires heat to thoroughly evaporate.Pistonboy might be thinking of propane, which requires a heated vaporizer to turn the liquid into a gas. They are started with gas.
http://www.cartrade.com/blog/2010/auto-guides/lpg-as-fuel-5.html
The vaporizer uses engine coolant to vaporize the propane:
[Broken External Image]
